IH 756 hydraulic
hogfarmer272
New User
I have a international 756 tractor and my 2nd (outer) auxillary handle has too much play. It feels like whatever is holding this handle to the shaft is just far too loose to engage the hydraulics properly. When trying to dump my loader bucket I barely get any movement out of it. I'm looking for what needs to be repaired and/or replaced to fix this problem. Anybody on here have the same or similar issue willing to help?
Ah well this all comes from way to much FIELD testing over the years . Pull the kick plate off inft. of the seat support ( 4 1/4 inch bolts) and you will see the linkage ya will find two blocks that are hooked to the handles This is where you will find the slop as the headed pins that hook everything together are just about plum slap wore out along with the holes in the link blocks . I have at times as a get me by removed them headed pins and replaced with 3/8ths bolts and lock nuts.
Hello Hello ..hog farmer.. welcome to YT! Here is a link
to the manufacturers online parts diagrams and
catalog. Find which parts in the linkage are worn the
worst that need replacing. Double click the part
numbers to select them to get the description, if
available and the price. Also if they show not available
you can scroll down a bit and you will see
..Replacements and Substitutions, click ..View more..
sometimes substituted parts that are available are
shown there. You will find the CNHI prices are mostly
ridiculously high. Do a web search with the part
numbers and hopefully you can find some parts that
have a somewhat reasonable price.
CNHI 756 online parts diagrams
That's where it looks like most the slop is, all that field testing has paid off and I appreciate the help! Is that headed pin or is it threaded in? It's not exactly the easiest spot to be working haha
