Mayrath hay elevator
glennullom
New User
I need a rim for a Mayrath hay elevator. It is a spoked 14 inch rim with an one inch axle. I am making an attempt at a repair but thought maybe a replacement was available. Any ideas.
Glenn in Ohio
Welcome to the Forums.
Sadly, your description doesn't give a lot to go on. A picture would help and if you are using the Modern view, you should be able to post pictures now. If you are using the Classic view, you will need 5 text posts on record before you can add pictures to a post.
Does your rim look similar to the one in this picture borrowed from the internet? That looks like a rim Mayrath might have made. Tire size might help give an idea of your rim width.
