Hi all,
I recently bought a multipower 135 off a relative knowing it has a hydrualic problem. The problem being that the hydrualic will not lower even when pushing down on the arms.
I have recently tried to open the PTO cover plate (to change the filter) only to discover that i cant get it open due to that large nut circled in a photo attached. I havent a socket/spanner to suit.
I have managed to find a workshop book which shows what is behind the plate. (i have attachd this also) I seems to be a head ache behind there and i dont understand how it would be possible to get the filter out due to all the auxliary pipes etc.
I was wanting to remove the hydrulic lift cover from the tractor to firstly get to the bottom of the issues of the hydrulics not lowering (I have a few ideas as to what it is but would appreciate any ideas also). Secondly i want to undo the nut from behind and remove the pto cover plate to insert a gasket. Thirdly i want to change the filter.
My question- Becasue this tractor has axuilary ports, im afraid that when taking of the hydraulic cover, these axualiary ports/fittings etc will be in the way or could end up damaged. I cannot seem to find anything on removing hydrulic lift covers with auxilary ports. Any help or guidance would be apprciated.
Thanks
Thanks
