datacommand
I am restoring my Ford 861 Powermaster. The original dash had three gauges and a dash light (not connected to anything). The original gauges were water temp, oil pressure and amps. My fuel tank has a float assembly for a fuel gauge, and it is more important to me to know my fuel levels without having to drop a yard stick in the fuel tank, so I replaced my amp gauge with a fuel gauge. I can always get my tractor home if I have fuel, normal water temp and good oil pressure. So my I want to replace my amp gauge with an alternator warning light.
The problem is I don't know what alternator light assembly I need. The tractor was upgraded to 12 volt negative ground with an alternator.
My second question is regarding the two openings for warning lights in the dash. What are they originally used for?
