Identity of a corn/wheat grinder or a bean/ seed seperat
Welcome.
If you are using Modern View, you are required to have one text post on record before you can post pictures in your second post. If you are using Classic View, you must have five text posts on record before you can add pictures to your 6th post. These requirements are due to the site's spam filters.
If you scroll down a bit from the message box, you will see a Choose Files button. click the IMG button above the message box, then use the Choose Files button to search your computer or phone to find the picture you want and select the fil that way. It will be added into your message, and you should see it if you click preview after it loads. Don't rush as it sometimes takes a bit to load. Also 7-7.5 MB is the maximum total size of a picture or tota of pictures that can be added to a post. Some phone pictures have to be reduced to load.
