I'm working on a 2 compartment tank that
has some holes in the starting tank. The
main tank is good.
I've cleaned the main tank and have rinsed
it with gas a couple times.
I'm not planning on using the small 2
gallon compartment but I will be coating
it after I repair the holes so that the
common wall to the main tank doesn't rust
through.
I want to protect the main tank and reduce
the gas fume hazard while in my shop. So
I'm thinking of pouring in some 2 cycle
oil and coating the walls of the main tank
. Hope to have this done and ready to use
in spring.
main tank is good.
through.
in spring.
