Case 30+4 trencher clutch slips
hub1987
New User
I have a 30+4 trencher that the trencher clutch slips when the chain engages the ground. It does trench in soft dirt, but slips when it grabs a rock. I see there is a spring loaded pin on the clutch that you can pull out. I am wondering if that is some type of adjustment? I also would like to get a repair and parts manual if you know where I can find one. Thanks
If its the same as a hand clutch then yes there is a spring
loaded pin to pull then u turn the collar a notch or two till
you have resistance on the handle to engage it. Post a
picture of it. You didnt say if its a hand clutch.
