Mf135 continental z145
tpiton
New User
I had to remove the starter form my 1967 mf135. I had the badluck of loosing the bolt through the starter hole inside the engine. I tried all day to get the bolt back with a magnet with no success. 2 question.
Is it problematic to leave the bolt in there?
What is the square plate with 4 bolts under the starter hole, is it a oil pan?
Remove the square plate and get the dropped bolt, the plate is for access to the flywheel PTO release bolt adjustment. Area SHOULD be dry, but there might be some slight oil leakage above the plate.
