Ford 5610 hydraulics
Yatsguy
New User
Hi gang, I restored a 1985 ford 5610, bought manuals, contacted dealers, no help! I found a used Long 1548 A loader (still attached to split Long tractor), I need help with how to hook up aux hydraulics to my ford ? I only need two lines( supply/return), I can forward pics of my valve body, does anyone here have that setup?
Hello Yatsguy welcome to YT! I am not a Ford guy but I searched for
some previous posts and I came across this one. So if
you want to hook the loader to the hydraulics but keep
the rear remotes open you MAY need to find a block
like the one shown in that post. Did you see the is MAY
is capitalized? That is to make sure know I do not know
anything for certain about what is needed to connect
this. You can also connect it through the remotes. Plug
them in and move the lever the right direction and it
will be working. One thing working against you here is
that this topic section does not have the highest
viewing traffic. If someone does not come along here
and help your with a more definite answer I would
suggest you post it on the Ford specific topic section.
When you view the post in the link just go to the Ford
in blue letters at the top that are a link to the right of
YT .. .. index. Had to add the weird spaces to get the
forum to accept my post. Then click the new topic
much like you did to post this. Best of luck!
Previous YT post on 5610 with a loader
t
Thank you for the response, I should have stated that this tractor has no remotes installed, I can t figure out which ports to attach remotes to, apparently it has never had auxiliary remotes or attachments?
Welcome to this forum
You need to install a hyd block designed to fit a tractor with closed-center load sensing such as your 5610. The block I'm referring to is the unpainted block in photo below.
