I tried to test an a circuit generator, but thought it was a b-circuit. I disconnected both harness wires and jumped d+to DF when idling. I got a couple of volts.
I removed the generator and took out to the local shop, and they told me that I had burned out the field.
I can't understand how this would burn out the field. When I look at the diagrams on this site, it looks like the DF terminal is connected to the field coil, routed around the magnets the terminates at the output brush, which should be +voltage, therefore no short. Why would it burn out?
I confess, this is not a tractor at all but a vintage sports car, but this forum seems to be the most knowledgeable about these old generators.
