MF 300 combine slow cranking
Jlee2792
New User
I have a MF 300 combine. It s turning over but doesn t seem like it is as fast as it should be. Should I be thinking starter is getting weak or timing?
That Mopar 6 does turn slow, but I would start with checking the battery,wiring
and then the starter.
Crank it with the ignition disconnected for 20 seconds then feel the cables for a hot point. This will ID a bad connection point for you.
