New pump, that did work, but due to issues with the previous owners plumbing and mounting abilities, I took it off.
Did all the replumbing, he had the canister type filter plumbed in on the suction side, which I did reinstall.
The problem is the keyway in the shaft that runs through the front axle pivot, it is very sloppy.
So the question I have is, how do you get that shaft out to either repair or replace it. It says something about a lefthand thread, in one manual, but does not go into any other details about it.
Thanks
Thanks
