lastcowboy32
The new tractor has a quick attach loader. Skid-steer style. It has a really nice bucket, but our manure pile is loaded with bedding. The bucket doesn't work worth beans on it. I borrowed a friend's quick attach manure bucket for a while. It worked OK, but it was more of a "spork" a shallow bucket with short/thick tines.
I'm trying to make something that is a pure fork with longer tines. It's 7' wide. It will have 8 tines (one foot spacing) when done. I have the middle two mounted straight and level so far.
I also need to build up the back with plate for reinforcing. I'm thinking that a solid plate from the top of the quick attach bracket down to the forks... which would hit them about 6" ahead of where they mount on the back bar... that would reinforce the back... level the tines even better and give them a longer depth of mounting to counteract the leverage at the tips.
The galvanized angle iron was all gathered from piles of torn down fence around the farm. Two owners ago, the owner had a chainlink fence business. He did all of his fence corners with 1/4" x 2" galvanized angle iron with 1/4" x 1-1/2" braces.
The last owner removed those fences and just threw the iron (well... actually steel) in piles...
The only thing I should have to buy is the plating for the back.
