C200 Valve Lash...
2500 B
New User
Ok, First thing is Im a new member, 2500 Series B, '39 JD B, '52 JD B, TO-20, Ford 600, Ford 800, Farmall Cub is my current list... LOL. I am putting new head gasket on the C200 engine in my 2500 Series and have lost my guide on which valves to adjust when #1 is on TDC. i know i can roll motor to TDC for each cylinder but i used to have a guide to only roll motor once and set all. I can find 6 cylinder version but not 4 Cylinder. Also does anybody have a cold setting to at least get started? i will gladly look for it if anybody can point me in a direction
With #1 cylinder at TDC at the end of the compression stroke (counting from the front) set valves 1, 2, 3, 5.
Turn crankshaft one turn to #4 TDC and set valves 4, 6, 7, 8.
Valve lash is .027" "hot".
(quoted from post at 07:02:23 12/03/19) With #1 cylinder at TDC at the end of the compression stroke (counting from the front) set valves 1, 2, 3, 5.
THANK YOU!!!!!
