Hydraulic control valve repair
2600 owner
New User
I recently baought a ford 2600 with a Allied 390 loader. The hydraulic valves are leaking fluid but I don't know the make to get o-rings. I try to add a couple of pics. the valves state made in UK and hace a maker C stamped on them. I hoped some one here could help I.D.
I believe that C with the box around it is the trademark for Commercial Hydraulics, made in the UK. It appears they are now a division of the Parker Group.
If you just need O-rings those can most likely be matched at a hydraulic shop, I don't know that you will find a kit for the valve. I expect the spools and body bores are precision matched fits. If you take them apart don't mix them up.
Thanks It is leaking from the top center between the hose connections....not sure what that is? But may be able to dissasemble and measure the o-rings and replace with 90 durometer viton rings.
