dutch1450
New User
I have an early 70's Ford 4000 4cyl. gas w/ slect o speed auto trans, my question is about lever used to raise and lower 3 pt. hitch it mounts with 4 bolts. can I unbolt it and rotate it up as to put the lever up higher, now it seems I have to bend over pretty far to put lever all the way down. or pick it up from the lowest point. Is it on a splined shaft ?
First off you have to get what you have correct. The 4 cylinger 4000 was last made in 1964 with the 1965 becomming a 3 cylinder and they are entirely different tractors, What would repair one probably will not work on the other.
