TractorLinks.com
Restoration & Repair Tips Board
Case DC main bearings
EL_Tractor
09-14-2018 11:48:59
Hi, I'm new to your forum, and this is my first post. I have an opportunity to buy a 1949 Case DC, non-running with a cracked block. I really enjoy working on old equipment, but in this case I'm trying to determine how treacherous a path I'm heading down. The cracks in the block are extensive and non-repairable involving the water jacket and oil galleries, but it appears that I can obtain an uncracked block from a couple of sources. The rod bearings are babbitt I believe, but the mains are liners. I'm not having any luck locating new liners. What options? Can the crank mains and caps be babbitted instead of using liners? I suppose I could even pour and/or machine my own liners assuming that they are just babbitt? What have others done in this situation?
Thanks!
EL_Tractor
09-19-2018 09:07:57
 Re: Case DC main bearings in reply to EL_Tractor, 09-14-2018 11:48:59
Earl, apologies for the late reply. Have been dealing with other issues at home, and had to lay this aside. Of course, thanks much for the information. When things settle down I will follow up with that, and also an outfit I found in Spokane, Washington.
Earl-IL
09-19-2018 08:47:59
Thanks for your rely.
Earl-IL
09-16-2018 21:52:06
Paul's Rod & Bearing in Parkville Mo. does a great job of Babbitt , repour inserts or rods. The Dc bearings you repour the old shells, install in block with shim pack and align bore. Is correct way to do the CC,DC,LA Case. Ph # is 816-587-4747
EL_Tractor
09-14-2018 14:22:39
Thank you! Will do!
53DC
09-14-2018 13:30:05
Good afternoon and welcome. The DC is a real workhorse and many parts are still available. If you post this on the Case forum you will get a great response. There are a lot of very knowledgeable people on that forum and they are very friendly. Some people on that forum sell Case parts and are a great resource. Good Luck with the project
