John Deere 950 oil leak
lbauco01
Trying to determine why I still have a problem. Initially I discovered engine/motor oil leaking from a weep hole under the tractor. Replaced the crankshaft/rear main seal and the drive shaft seal. The first time the tractor was put to use, I cut grass using bush hog and all seemed fine (took about 30min time to mow). I started my drive to another field and got about 3 miles and the transmission began acting up- like it was getting "tight" and did not want to pull so I stopped the tractor in place and waited till I could pull the thing home.
"I stopped the tractor in place and waited till I could pull the thing home."
NOT sure what you've got going on, but the LAST thing I'd do is "pull" a machine that acted like the transmission was "tight".
You are asking for a HUGE repair bill. And transmission parts availability for a "950" may be "sketchy", at best.
Mite as well have DRIVEN it.
If you haven't already injured it worse, buy, beg, borrow, or steal a trailer.
