Farmall Super A Help!
I have a Farmall Super A that we are restoring but running into some issues. We can not get spark. We have timed the mag to the tractor, new spark plugs, and new wires. The mag works, we took it off a already running tractor. Every couple hundred engine turn overs it will act like the engine is tied up. Take the mag off and it frees up. It did this with 2 different mags. Is it the governor? Has anyone experienced something like this before?
Maybe you have it off 180 degrees. Easy to do. Put number one piston at top dead center on the compression stroke and see where your rotor is pointing.
