TO20 Ferguson
Sivert
New User
My 1952 to20 cuts out like you hit the kill switch to off then comes back sometimes a second other times longer where it will die, but starts right back up. I have the 6 volt system with all original equipment
with exception of electronic ignition in the original distributor. Thanks for any help anyone can provide.
I'd check and make sure all the wires from the switch to the coil etc. are clean tight and bright. Sounds like an intermittent open in one of the wires so you hit a bump etc. and the wire moves and does not make contact for a moment
