Hay hay hay
I?m in the process of putting new bearings in a Reese drum mower. In an earlier post about the problem of getting the drums out of the mower you suggested using a jack or Porta power. If I can find a sturdy beam Long enough for this project and can chain it around the frame I?ll try pushing the pod out of the mower. Do you have any concerns about bending the frame in this process? Or any suggestions how to make it work easily and safely? Thanks for your help.
