Mike(NEOhio)
- Location
- Newbury, Ohio
Getting my E4 back together. It originally had a 6v with cutout relay and three position light switch but the gen was changed to one with a two coil regulator. The A terminal is connected to the bottom of the reg and the F terminal is connected to the F on the reg. The wire from the ammeter goes to the B on the reg. and there is another wire from the light switch that would normally go on the generator's F post. Only one place left, the L terminal. Do I need it? The reg looks like the voltage limiter is already grounded to its base. No lights on the tractor, long gone.
