ford 2000 power steering pump
(quoted from post at 07:49:13 06/12/18) mounting boss is too long on replacement pump
Has anyone had this problem? Did you modify the boss on the pump or modify the bracket?
It looks like the easiest way is to grind 1 inch off the mounting boss. anyone done this?
In order to get an answer you have to tell what tractor you are asking about. Three or four cylinder?
I have solved the problem, I paid the extra $300 to buy the correct pump.tanks for your interest/
Mike
