Farmall 400 - stuck motor
Paul0807
New User
I have a Farmall 400, and the motor is stuck. I was told to put acetone and hydraulic fluid in the cylinders. Is this an accurate or appropriate suggestion? If it is ok to do, how much of the acetone, and how much of the hydraulic fluid do I use? How long do I leave it in there?
I've freed up many an engine over the years and have told many on here how to also. I use ATF and only ATF. Fill the cylinders after making sure it does not have water in them. Pull one plug at a time then put it back in. Then pour as much down the exhaust as you can so as to get to the valves. Let it sit about a week set a good 12 volt battery on pull the plugs and use short fast taps on the starter button while watching the crank pulley for movement. I have freed up 30 plus engine doing that
