MF180 PTO Hydraulics
I have a MF180 2 stage clutch, multipower. I have lost PTO and hydraulics, tractor moves fine. Do I need to adjust the clutches? I have done
clutches in cars and trucks this one has me lost!
Two stage flywheel clutch tractors, there's a chance the PTO drive disc in the clutch may have lost the internal splines, or the disc drive hub rivets have failed, or the disc facings are gone. When that happens, complete drive line will stop to the three point hydraulic pump, two stage auxiliary pump, and PTO shaft. Any adjustments are for clutch release only, both clutches are spring loaded, main by coil springs, PTO by a Bellville spring.
