mr.precision
Been restoring tractors for many years. As you know, most of them that have been sitting outside have water in the gearbox/differential. I used to flush out the mess with diesel oil.Recently acquired a 1957 John Deere 420W, which had the usual goop come out of gearbox drain plug. I had an old bucket of universal hydraulic fluid in the shop, and figured it would make a good flush. So in it went, drove around for a few minutes and drained it out. Replaced with the proper amount of GL-5 gear lube. Maybe one hour of use....checked the fluid level and it was so foamed up that it ran over the top of the fill plug. So obviously I didn't get all the hydraulic fluid (and maybe water) out of the diff.
Picture below is after the draining out the NEW GL-5.
Lesson leanred:
1. UTF probably not a good flush for a gearbox that uses gear lube.
2. In the case of water contamination, you may not get all of it the first time around.
Lesson leanred:
