unknown cable
Tolmkr
New User
I have a 52 M and it has a cable that runs into the tranny case by the hydraulic lever. Can't find anyone that can tell me what it is
that is for an m+w 9 speed kit. it gives you higher ranges in reverse, and 1 thru 4. also doubles the pto speed. very handy option and makes the tractor wayyy more useful as a chore tractor. with the cable pushed in, you are in normal range, depress the clutch, pull the cable out and it shifts into high range. you may need to lube up the cable if it hasnt been used in a while.
also, be sure you come to a complete stop before shifting the 9 speed unit. never shift on the fly.
I thought maybe if you pulled it,it would say "The cow says moo" The duck says quack quack" "The tractor says vroom". lol
So, Does it have a lockout for 5th in the high range or can you run in 5th in high range and it just doesn't change the ratio? I really appreciate the info. Couldn't find anyone that knew this. Also, is this still just an M or a M+W? It has no markings that signify the +W.
in fifth gear the trans is direct, so the speed is the same whether in direct or over drive. m+w was a company that made aftermarket parts for many different applications. heisler was another company that also made things.
