I have a carb from a Farmall F12 that needs to be rebuilt. I have cleaned, sandblasted and soaked in PB Blaster and the majority of the adjustment screws and fittings(most of which are brass and we know fun it is working with brass hardware) are stuck in place. I would like to remove everything so I can soak the the carb in solvent before I reassemble. Should I soak it for longer? Should I heat the casting up? Any advice would be appreciated.
Thanks in advance!
<image src="http://forums.yesterdaystractors.com/photos/mvphoto11574.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto11575.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto11576.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto11577.jpg"/>
Thanks in advance!
