jeff juber
New User
new to this site - have a piston sleeve question about a farmall H that had a rusted stuck engine . soo i had to remove the #3 piston and sleeve as one piece - there wasnt any freeing it up - but now iv seen the letters stamped into the deck of the block by each cylinder - #1 & #2 are stamped " E " - #3 ( the bad one ) is stamped " C " and #4 is stamped " D " ... question is - if i purchase a new sleeve piston kit which i suspect come as all 4 being the same size - am i going to have issues with the cylinders marked " E " being to loose and the others to tight?? According to the tractor / block and head numbers it is a 1941 machine -- but believe was rebuilt at one point because it has high compression pistons in it - not flat top . thank you for any answers or help !
