Replacement steering wheels and decals
ScottNC
I need a replacement steering wheel for my David Brown 885. Is there a chance the steering shaft is generic enough to allow a wheel off something else to fit? The original steering wheel is not a suitable for repair.
I also would like to find replacements for the the dash decals. The gear selection pattern, engine RPM/PTO speed, 3-point quadrant and PTO decals especially.
Is there a go-to for David Brown parts in the U.S.? Not oil filters, radiator caps and the like but replacements for things like I just mentioned above plus the plastic knob for the 3-point travel lock or the plastic quadrant stops?
The shaft is tapered I believe,so I don't know if one from a Ford,Oliver or some such thing would fit or not. Any Sparex dealer should be able to get that other stuff. Somebody said Agco owns a good share of Sparex now so they might be able to get what you need. Ricks Ag Parts out of Wooster Ohio specializes in parts for foreign built tractors. You might call him. Last parts I got from him for my Fiat built Oliver were Sparex.
I got some parts for my DB Built Oliver 500 from David Brown Parts Ltd out of England,but the shipping was pretty high.
(quoted from post at 10:39:04 02/04/18) The shaft is tapered I believe,so I don't know if one from a Ford,Oliver or some such thing would fit or not. Any Sparex dealer should be able to get that other stuff. Somebody said Agco owns a good share of Sparex now so they might be able to get what you need. Ricks Ag Parts out of Wooster Ohio specializes in parts for foreign built tractors. You might call him. Last parts I got from him for my Fiat built Oliver were Sparex.
I'll do a search on Sparex and check them out. Thanks.
