Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Massey 44 starter
NeilY
01-12-2018 22:49:03
Will a starter off a Massey 444 work on a 1950 Massey 44?
David G
01-13-2018 12:46:23
 Re: Massey 44 starter in reply to NeilY, 01-12-2018 22:49:03
Go to Goldburg's site.
buickanddeere
01-13-2018 11:58:12
Took almost a minute to google MT39 and find the info.
http://www.delcoremy.com/getmedia/a6f943ce-00ac-40b3-8725-7324cee819a1/Delco-39MT-Single-Page-Brochure-1-16.pdf.aspx
http://www.delcoremy.com/Starters/Find-by-Model-Family/39MT-Gear-Reduction-Starter#features
buickanddeere
01-13-2018 09:26:15
Starters are as generic as socks . Just look at the number of mounting bolts , pattern, gear tooth number , tooth pitch and rotation. New Generic starters from eBay of your local parts shop son’t Cost any more than a pre abused starter . There are some outright powerful starters such as the MT39 which will wail over even an 8.1 Diesel in the winter .
NeilY
01-13-2018 09:42:43
 Re: Massey 44 starter in reply to buickanddeere, 01-13-2018 09:26:15
Thank you buickanddeere, can you send more info
On that powerfull starter you mentioned as I am
Rebuilding my h260 and have a set of M&W pistons Im putting in. Compression ratio will be higher.
krm
01-13-2018 07:45:36
Starter for a Cockshutt 40 or 50 is the same as a MH 44 except for where the battery cable mounts.
NeilY
01-13-2018 08:04:19
 Re: Massey 44 starter in reply to krm, 01-13-2018 07:45:36
Will it work? The nose cone on my original starter looks Just a little longer than the starter off the 444
Starter?
centash
01-13-2018 06:11:36
444 is 12 volt, 44 is 6 volt. If converting to 12 volt, you will need new lights, generator, regulator, etc. Ben
David G
01-13-2018 06:05:45
I would believe it should fit if 44 is 4 cylinder and not 6, do not know about 6.
Dieseltech
01-13-2018 02:10:31
Believe it will bolt on, and it's 12 volt if I recall.
NeilY
01-13-2018 06:21:10
 Re: Massey 44 starter in reply to Dieseltech, 01-13-2018 02:10:31
My Tractor has already Ben converted to 12 volt
David G
01-13-2018 06:41:30
 Re: Massey 44 starter in reply to NeilY, 01-13-2018 06:21:10
I put a gear reduction starter on my MH44 EFI from Goldburg, the compression is 9.5:1, it cranks over a lot easier.
