I have a true problem with my Ford 2110 LCG tractor. the year it was made was 1967. I just recently changed all the oils and fluids on the tractor and ever since I did that I have had countless problems with the cooling system. Just the other day I started it up and it started to overheat really bad. I shut it off and let it cool down. when I got this tractor I replaced the thermostat with a new one and I also replaced some other cooling parts within the cooling system. but that was about 5 months ago. and the cooling system has had countless problems ever since I changed all the fluids about a week ago. I pulled it out of the garage yesterday and it started to overheat again so I shut it off. After a couple minutes I started it up again and it was cooled down a little bit.Then it starts spuing radiator fluid out the drain valve on the right side of the engine block. It hasn't stopped leaking out of that drain valve for a couple days now. and if you squeeze one of the radiator hoses it shoots out radiator fluid. Do I need to replace that drain valve? or what could be wrong with my cooling system?
