Broken Wheel Clamp Studs
albent_33
New User
Hi, I have looked through the other threads and have found no definite answer. I recently picked up a 1941 farmall h with a 3 point hitch not running for $350. While i was taking off the front wheels, I snapped the stud that goes through the hub and wedge that is used to clamp the rim to the hub. The other 2 studs look rusted out near the hub. So my question is, how should I go about fixing this issue? Drill them out? Pound them out? Are they threaded into the hub or just stuck through? There is a square head on the back side of the hub. Thank you for you help!
it is just a square head bolt. you can drive it out. replace it with a grade 5 or 8 hex head bolt.
(quoted from post at 11:19:42 12/21/17) it is just a square head bolt. you can drive it out. replace it with a grade 5 or 8 hex head bolt.
I tried that tonight and it still doesn't want to budge. I also applied heat and tried to bang it out. Should I drill it out now?
Once rusted in they can be bears to get back out. It may take a lot of ATF soaking and heat and or a press to pop them out
I'd blow 'em out with the smoke wrench in less time than it took you to type your post. Lacking that, and air hammer with a punch tip would probably rattle 'em out.
