3 point hitch rebuild
Not sure my nomenclature is right, but I need to rebuild the 3 point hitch on my 464. The "ends" on the 2 arms that hook up to the implement are shot, meaning they are loose, one of them actually fell out. My question is how to get new ends on these arms, or should I just buy new ones?
this is all new to me, so thanks for any help!
You can do both. They make lift arm repair ends with the the ball socket size you require (cat I,II). You cut off the worn out ones and weld the new ends on.
Or you can buy replacement lift arms.
