674D international
My question is, the clutch on my tractor will not pull until you work it back and fourth from reverse to drive several times, the more you do that the better and stronger the clutch grabs. Finally starts working to the point of no issue, until you let it sit overnight and then the problem starts again, it is full of hydraulic oil, 9 gallons I believe is what it held, any advice would be greatly appreciated
Sounds like oil on the clutch or it's just
shot. As far as I know, the 674's were ever
offered with a TA like some of the others.
Both of mine have a fully mechanical
clutch. Might post your question on the IH
board below for more replies
Ross
