I have a Ford 2n with the front mount distributor that has been changed to 12 volt. After changing the condenser in the distributor along with the gaskets because it died one day and I coudn't get any spark. I can no longer get the distributor cap to fit So I took the distributor back off and it looks like the shaft with the two teeth in the distributor aren't reaching all the way to the shaft in the tractor that its supposed to meet up with. Also if you have the distributor off of the tractor should you be able to spin it freely?? Is it possible that if the bushing went bad in the distributor the shaft may have moved onward enough to not meet up with the slotted shaft in the tractor?
