older 2500 gehl loader
jimbob456123
New User
I have this older gehl loader when I go to start it it moves forward and backwards . I really don't know where to start to fix my problem I put a different motor in it . It works great but hate the movement when starting it .anyone have a answer. Thanks ..Greg
Hi
It's not something simple like the motors moving around on the mounts, and pulling a linkage/ or cable that controls the direction. I had a Diahatsu
4x4 jeep once it had a transmission mounted park brake. When it was government tested every year they did brake performance tests on powered rollers
measuring brake resistance. every time they tested the park brake, it would rev the motor when the torque coming back up the shaft pulled the
throttle cable as the motor moved on its rubber mountings.
Regards Robert
That has separate hydro drives, one for each side. Make sure the control rod ball joints are good on each end. When they are worn really loose and the Tee handle is locked in neutral the machine will creep. The 2500 I had did the same thing, loose control connections. The best way to set the linkage is with all four wheels off the ground when adjusting the rods for neutral, and even then they can be really touchy..
