I am sure this must have been discussed a thousand times on this site but maybe you will enjoy my picture anyway!
We have a Thompson refueler c1950. It is powered by an English Ford 10hp side valve engine and is presently 6V positive earth which we want to convert to 12V negative earth.
We have a 12V coil and ballast resistor, it will be no problem changing the few light globes, there is no windscreen wiper and I am sure the starter motor and horn will really enjoy the 12V.
This leaves only the dynamo (generator) to take care of.
Do I need to find a voltage regulator/cut-out or can I just put a diode in the main output lead of the dynamo and give drive to the field coil direct from the ignition circuit?
