Another Question on Electric Motors!!!
Where's a good place to buy starter capacitors for electric motors??? I got one i'm hoping to rebuild but it's so sketchy. The wiring is a little cracked on the inside of the motor, and i don't know the model #,so i can look at investing in new wiring . All i know is that the motor in general electric and its from a crop dryer. The machine was left on the farm my dad bought and i'm his "Handy Man". I used to have the model # plate, but it fell off and i can't find it. :cry: :cry: :cry:
Anyway, what websites are good for high quality capacitors. i'd rather go to a good website than to go to a bad one... :wink: :wink: :wink:
Thanks Again!!!
Bryce
If you know what you want, you can find name-brand 'lytics on ebay reasonably.
Grainger will have and start cap you might need, but one of the higher $$$ places to buy them.
Any place that repairs electric motors will sell caps. Like I said on your other post, however it is a lot more likely to be the start ending switch.
(quoted from post at 15:14:19 11/06/17)
That was supposed to be start "winding" switch.
What part of the crop dryer is the motor from? If it's from the fan/heater chances are it's 3450 rpm. Worked on dryers for 26+ years. Do you know brand of dryer and where motor came from on dryer? If so I should be able to help you. Actually getting close to 70 and still doing it part time. I'm retired LOL just like a lot of other folks.
The good news is that you can not install too high of a mfd value. Bigger is better . Higher the starter cap capacitance , the lower the starting current and the higher the starting torque .
The larger the run capacitor , the lower the current in the cable out to the motor and the higher the voltage will be at the motor terminals .
Just ensure that the start and run capacitors are rated for at least 370V or higher .
Install the largest 370 or 440V caps that will fit under the cover.
