1946 BN IHC
Does any one out there happen to have an IHC 2 furrow pick up plow in their inventory or know of one near their home base.
What I am wanting is some measurements of particular parts so I can reproduce them for my refurbishing of the IHC #8C that I have and am going to re finish in the spring. Since the little Genius and the #8C were similar; the Little Genius being on the U.S.A. side, and the #8C on the Canadian side of the border and a few other minor adaptations: I am looking for the measurement of the rear land side {which is longer} when there is no rear furrow wheel; for the measurement of the stiff pickup rod that goes from the hitch to the frame; the measurements of the bracket at the top of the pickup rod.
Most of the two furrow plows / at least the early ones had steel wheels. I will desire to covert this plow from the present steel to rubber so if any one in Ontario or Michigan has any parts I would like to hear from you in particular in regards to any parts extra you might have or might like to swap.
Thank you. WM.
Thank you. WM.
