case ih iron guard paint
Lee460
I am going to spray some panels with IH 935 blanc white. I always used just Tractor Supply oil based enamel in the past with there hardener and had good luck for someone that has no ideal what he is doing. My question is the 935 a oil based enamel that I can use the hardener I have or do I need something else, or nothing at all? Thanks for any help. Jim Lee
The CNH paint is a synthetic enamel now. You need the proper hardener. About any place that sells automotive finishes will have the hardener that you need, if your CNH dealer doesn't.
Loren
