Restoration & Repair Tips Board
Re: Grandpa’s Seized Farmall H
hunterguy92
10-06-2017 19:40:17
I will double and triple check for the starter and gears, but as far as I know the motor is locked up. The muffler is gone but there was a can over the exhaust, so hopefully water has stayed out.
Let’s say worst case scenario there is water in there; what next?
D beatty
10-06-2017 20:00:31
 Re: Grandpa’s Seized Farmall H in reply to hunterguy92, 10-06-2017 19:40:17
On a stuck motor you will want to take valve cover off and also check for stuck valves. If you free up pistons but have stuck valves you can damage push rods and rocker arms.
