Restoration & Repair Tips Board
Re: Grandpa’s Seized Farmall H
Charlie M
10-06-2017 17:19:06
I guess the first thing I would do is make sure it is seized up and not stuck because the starter is locked or because its stuck in 2 gears. Assuming is seized up was it closed to rain? If its had water running into it for this long probably the only fix is to tear it apart as it will be rusted badly and at least 2 cylinders will be full of water. If it has been protected then some of the mixtures guys on here recommend might get it loose with some time.
hunterguy92
10-06-2017 19:40:17
 Re: Grandpa’s Seized Farmall H in reply to Charlie M, 10-06-2017 17:19:06
I will double and triple check for the starter and gears, but as far as I know the motor is locked up. The muffler is gone but there was a can over the exhaust, so hopefully water has stayed out.
Let’s say worst case scenario there is water in there; what next?
D beatty
10-06-2017 20:00:31
 Re: Grandpa’s Seized Farmall H in reply to hunterguy92, 10-06-2017 19:40:17
On a stuck motor you will want to take valve cover off and also check for stuck valves. If you free up pistons but have stuck valves you can damage push rods and rocker arms.
