Hydraulic fluid & filter change, T340 IHC
T340
Where are the drain plugs for the Hydraulic system? Service manual ordered, but not yet received. Water in the system. Any help on the fluid/filter change.
I have an international 340 back hoe. Everything is fed from the transmission housing. There is no separation of oil. takes hydraulic or 20wt oil. drain plug is on the bottom of the trany housing. Level plug is under the right foot rest. If you have a problem with water just loosen your plug till it drips. water will come out first as water is heavier than oil. you really may not have a problem. small amount of water/condensation will happen.
(quoted from post at 20:12:15 10/10/17) I have an international 340 back hoe. Everything is fed from the transmission housing. There is no separation of oil. takes hydraulic or 20wt oil. drain plug is on the bottom of the trany housing. Level plug is under the right foot rest. If you have a problem with water just loosen your plug till it drips. water will come out first as water is heavier than oil. you really may not have a problem. small amount of water/condensation will happen.
Thanks. Got it.
