Hoof Product Governor BD539A seal replacement
I currently have a Hoof Product Governor BD539A that has the seal blown out of it. Trying to locate the p/n for the seal or the replacement p/n and where to purchase it so that I can get the governor repaired and back on line.
Thank You,
Ed Porath
Here's some numbers I've saved....
For the main shaft seal, Pierce # X-1220, John Deere # AE29510, SKF/CR # 6903.
For the cross shaft seal, John Deere #T19564.
Please post back if these fit, for the next guy that finds this in the archives.
(quoted from post at 10:49:43 08/09/17) Here's some numbers I've saved....
I have searched for both P/N's with no luck, do you know where these can be purchased, thanks for any info you have.
Ed Porath
(quoted from post at 08:58:54 08/12/17)
Ed Porath
Any John Deere dealer can get the DEERE part numbers. (For the cross shaft seals I only have a DEERE part number and it doesn't seem to cross to SKF/CR or Timken).
The SKF/CR part # should be available through most any auto parts store, or industrial "bearings and drives" type of place.
(quoted from post at 06:58:54 08/12/17)
Ed Porath
Just located the John Deere seal p/n AE29510 on Ebay this morning and ordered it, will let you know if it works or not when I receive it, thanks again for your help.
Ed Porath
(quoted from post at 11:17:42 08/12/17)
I assume that I'm looking for the main shaft seal, it's leaking just in front of the pully.
Ed porath
It appears that the AE-29510 is a good replacement seal for the main shaft of the Hoof Governor BD-539F, Had it installed & so far no leaks, thanks for this information and ordered another set as a spare!!
Ed Porath
Baja, Mexico
THANKS for posting back. Now, when someone finds this info in the archives the will know it actually fits!
(quoted from post at 09:39:23 09/14/17)
Some more belt-driven governor shaft seal info, probably for a different series:
DEERE # AH78900 (NLA)
Can use: SKF/CR # 6203
Shaft 0.625"
Bore 1.124"
OD 1.128"
Width 0.25"
Weight 0.022 lb
