TractorLinks.com
Restoration & Repair Tips Board
Re: 64 ford 4000 help please
Noahsswan
09-13-2017 14:23:02
And I was off on the year it's a 1963
Do these have a timing chain or are they gear to gear
And what would the chance of it "jumping a tooth"
mite-help
09-14-2017 18:12:00
 Re: 64 ford 4000 help please in reply to Noahsswan, 09-13-2017 14:23:02
Your trouble with the timing reminds me of one of these I ran into years ago--tore it down to check gear keys-found the cam gear [aluminum] had a steel hub that had turned loose, floating around.
noahsswan
09-16-2017 20:23:02
 Re: 64 ford 4000 help please in reply to mite-help, 09-14-2017 18:12:00
That sounds very interesting Was it the same machine
Steve@Advance
09-13-2017 19:51:09
Timing gears, no chain.
Extremely unlikely the cam is out of time.
But if you want to check, pull the valve cover, set the crank at TDC. Watch the #1 and #4 rockers. While rocking the crank slightly back and forth, you will see which set of rockers is in the overlap position, when the ex is closing and the in is opening. Split the difference when both are closed. The crank should be at TDC.
noahsswan
09-13-2017 20:48:40
 Re: 64 ford 4000 help please in reply to Steve@Advance, 09-13-2017 19:51:09
that was my last option to what may be wrong after thinking there is a short heavy duty looking spring that is connected to the hand throttle and not sure where other end goes i wanna say with the research i have done it may possibly be the gov spring but i don't think that will cause the tractor to have to be advanced as high up as it is its almost as high as it will go just to start
