Howdy Gents & Happy Labor Day Weekend
I somewhat tore apart a MF 202 Workbull and I have some wiring questions now that I'm putting it back together. I'm pasting a before and after/proposed diagram. The way this was wired has me scratching my head, and I lost some of my tape on the wires telling me where they go, so in the diagram anything marked 'unk' means unknown.
My questions will focus around my proposed diagram, please let me know if you see any issues I'm not asking about as well. And thanks in advance!!
1. Is the ammeter I bought 'strong' enough to be wired between the battery and alternator? This is what I have:
http://www.ebay.com/itm/Ammeter-Amp-Gauge-fits-Massey-Harris-81-82-201-202-203-333-404-444-555-303-I-24/232259520208?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
2. Given that I have an ignition switch with a 'start' post, do I really need to use the starter button or could I skip that? My assumption is that they do the same thing and that either one or the other is needed (but not both).
3. Neutral Safety Switch - Assume this connects inline between the start switch (whether using the start from the ignition switch or starter button) and the start post on the solenoid. (I have a 4 post + ground solenoid)
4. Assume I don't need to use the 'i' post on the solenoid?
5. Not 100% sure where to connect the #1 wire from the alternator. Can I hook this to the acc on the starter?
<image src="http://forums.yesterdaystractors.com/photos/mvphoto2914.jpg"/>
