To 35 Lift to high and lower to low. Please HELP
gunsmith
New User
Ok guys I may be over my head. I replaced the pinion and wheel bearings on my Massey To 35 and I had the top cover off now my lift arms are not working correctly they go up to high and lower to low, whe up to high the hydrolic pump wants to continue to run I hav looked inside the inspection cover and both levers are in front of the the roller. I did work before It was tore down so I know something is not assembled correctly. Any Ideas.
Make sure the DRAFT lever is down halfway or lower, it should NOT be used to raise the arms, only for plow control. The POSITION control lever should raise-lower the arms, and the upper limit bolt set so the arms stop at the top. Lift the arms fully up by hand, scribe a mark across the top cover and the arm. The stop is set correctly when lift stops when up, and arm mark is 1/8 inch BELOW the cover mark. Pump relief valve should NOT blow if upper stop limit bolt is set correctly.
