I have a 1020 jd that lost its hydraulics when I was
stacking hay. I changed filter cleaned screen witch
was clean and ran test on transmission pump per
manual. No fluid at return line going back to sump.
Checked check valve above filter housing and screen
in front pump. All looks good. Then noticed pto
wasn't working either. Barely turns and when shut off
with pto engaged you can turn it by hand. Any help
would be appreciated. Thanks
