first hello to all as new member!
already learned a lot reading posts but havent found exactly the prob having.
Ford 4500 3 cyl diesel loader/backhoe
all working as it should till blew backhoe hose.
replaced 11/12 hoses from control valve..12th just couldnt get off. Hoping lasts till finish project. Right...
topped fluid, ran, topped off again.
Prob is the boom seems fine but stick seems to not extend beyond vertical and feels like mechanical clunk at endpoint. Bucket didnt want to move more than bout 6" at teeth.
Thought I was very careful bout matching up hose locations.
After fooling around a while eventually got stick fully extended and bucket closed using weight of boom for assist but wont open fully.
Stick seems to extend if use another control with it??
Is this air in lines causing prob??
Is there a bleeding process, other than my knuckles changing hoses, when replacing hoses??
All cylinders working fine before hose blew. Thx, jim
